Mill Conversion to Plasma cutter.
Re: Mill Conversion to Plasma cutter.
spidey4fun wrote: Mon Sep 07, 2020 9:57 pm Thanks for the feedback. I hadnt given much thought where to best place the earth lead. I can see how connecting it to anything other then the pipe might cause arcing issues.
I also run a separate earth ground from the material being cut to an 8 ft. copper clad ground rod driven into the ground located about 10 ft. away from the machine. In the photo, you will notice a large copper lug mounted to the end of the machine support frame. In my case the cable attached with the clamp to the material being cut has the other end attached to this copper lug. I then attach both the earth ground cable clamp and work lead clamp to this copper lug. So this effectively connects both the work lead and earth ground directly to the material being cut.
spidey4fun
Post by spidey4fun »
I've started my next project and this is the first part cut on my DIY plasma cutter..
Greolt
Post by Greolt »
Looking good Brad.
You have come a long way from cutting spider eyes on the laser. ๐Ÿ‘๐Ÿ˜
spidey4fun
Hey Greg. By the time I got to spider eyes I'd learnt heaps. This is where it all started...
I think this is your Milwaukee I used before I purchased my own when the above router broke.
And I have to say without your help, and advise from the very start I doubt I'd be where Im at now. So THANKS!!!!! :Yay
spidey4fun wrote: Sun Nov 15, 2020 1:40 am I've started my next project and this is the first part cut on my DIY plasma cutter..
Very impressive indeed!!
:Like :Like :Like :Like :Like
spidey4fun
First large cut. Im still a little unsure why the Plasma cutter switched off at the end, but recovered the cut easy enough.
spidey4fun
This should work.
And my other new little helper. :)
Well looks like you having fun with DIY projects, and sharing them with us. I built a saw like that years ago and the secret is do not oil the blade while cutting. the oil keeps the swarth from falling away from the metal and gums up the process. Dry is better IMHO :-D
spidey4fun
So here's my first attempt to cut a pipe.
A little more fine tuning required but it seems to work. :Yay
Ah the old third time is the trick :HaHa remember any step forward is a success, little fine tuning and you will be there. :Like
Here is a similar tube cutter I built, I cut and welded up a manual 3 jaw chuck for an easier transfer of power to the tube.
have fun, DIY is alive and well in your shop :Yay
spidey4fun
Yes i'd seen your video. It gave me the idea to use the metal braided straps. Thanks.
spidey4fun
Some more plasma cutting on my project.
That's another great video!! Please keep them coming.
Greolt
Post by Greolt »
Going great guns there Spidey. ๐Ÿ‘
spidey4fun
Here's another..
spidey4fun
Here's a quick tutorial on altering a mach3 screen. Thanks for the idea Greg. Hope it's useful to someone.
ralphieboy127
Post by ralphieboy127 »
Hi There,
I too am using Mach3 (I clicked on every feature there is over the last four years.....LOL) I am also using a floating head with a homemade macro
It works great, I am using the spindle delay feature for my pierce delay with an on screen DRO to adjust the pierce delay, I would like to also put the cut height on an on screen DRO to adjust the cut height (instead of modifying my macro) do you think you could help me with this?
Thank you, Ralph
ralphieboy127
Hi There,
Thank you, Ralph
spidey4fun
Hi Ralph. Did you get this sorted? It's been a long time since I been on this board. brad@spidey4fun.com
Brad.
Welcome back Brad! I had forgotten all about this thread. Your recent post has jogged my memory and I will take another look at some of your neat projects you shared above.
Return to โ€œDIY Plasma Table & Accessory Discussion Forumโ€
