Tree frog help
Cracker Red
Tree frog help
Post by Cracker Red »
Not sure if I did this correctly, but if someone doesn't mind taking a look at this inkscape vector I would appreciate it! I cleaned up a bunch of extra nodes all around the border, which will hopefully allow a better cut (If I understand correctly).
I still do not understand how to manipulate vector lines to clean up a drawing. I'm sure there is an easy way to join this node to that node....but I haven't figured it out yet.
I can erase and move the vectors around no problem.....but if the "Trace bitmap" function doesn't trace the pirture perfectly (never does?) then I'm left with a partially usable drawing where I might need to join nodes together to cut something out.....so far no good.
treefrogs.dxf
DXF
Re: Tree frog help?
Post by DXF »
Looks great! I love frogs, have a bunch of files of frogs. I've never used inkscape. I use Corel, Adobe and Plasma Cam. Nothing traces files perfect. You'll always have to clean them up.
Dave Hanks
muzza
Re: Tree frog help?
Post by muzza »
I don't use Inkscape either, I gave up with it and bought CorelDraw a few years back, but in Corel you would select all nodes and then convert to curves, then you just drag and move the arrows on the nodes to move the line around as you wish, maybe Inkscape is similar.
I've joined the nodes in Corel Corel
Murray
treefrogs.dxf
beefy
Re: Tree frog help?
Post by beefy »
Like Murray I gave up on Inkscape too but for a different reason, at the time there were much more tutorials (Google & Youtube) and paid courses available (I bought everything I could find and it's worth it).
If there's one thing I've learned about software, it's that you can mess with it for months or more trying to figure it out, but when you have good teaching info ........................quite different.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Largemouthlou
Re: Tree frog help?
Post by Largemouthlou »
Turned out very nice thanks!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
muzza
Re: Tree frog help?
Post by muzza »
Apologies, the wife saw me with this frog yesterday and wanted one, I went to cut it and when I imported it into sheetcam I realized it still had some duplicate lines they have now been fixed.
Murray
treefrogs.dxf
Largemouthlou
Re: Tree frog help?
No sweat Murray!! Close enough bud!! LOL
1250 hypertherm
CandCnC electronics
muzza
Re: Tree frog help?
Post by muzza »
Cut it out, hit with some rattle can color, cut a stainless backing, glued it together and hung it on the wall for her for mothers day a day early :D
Thanks Cracker Red
Murray
Largemouthlou
Re: Tree frog help?
Looks great!! :D
1250 hypertherm
CandCnC electronics
DXF
Re: Tree frog help?
Post by DXF »
Turned out cool!
Dave Hanks
billphillips
Re: Tree frog help?
Post by billphillips »
Thanks for the Frogs, will cut later today
Davewynes
Re: Tree frog help?
Post by Davewynes »
Aewsome File Cheers For The Share
WyoGreen
Re: Tree frog help?
Post by WyoGreen »
Thanks for the file. I'll give it a try once I get my new compressor up and running.
Router
Laser
CNCCAJUN
Re: Tree frog help?
Post by CNCCAJUN »
beefy wrote:Like Murray I gave up on Inkscape too but for a different reason, at the time there were much more tutorials (Google & Youtube) and paid courses available (I bought everything I could find and it's worth it).
Keith.
Hello Keith,
Could you elaborate on the training path you took for CorelDRAW. I have CorelDraw 7 & have been messing with it.
One of the posters on here offers a class but I wanted to at least have some working knowledge before going that route.
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
lucky7sg
Re: Tree frog help?
Post by lucky7sg »
I like this - thanks
VPT
Re: Tree frog help?
Post by VPT »
Nice, I like it too! Thanks!
harrymorley
Re: Tree frog help?
Post by harrymorley »
great file.....thanks alot for the share
plasmapros
Re: Tree frog help
Post by plasmapros »
Great design! I love when old threads you've never seen are discovered and bumped to the front page!
Beevo
Re: Tree frog help
Post by Beevo »
thanks
tinspark
Re: Tree frog help
Post by tinspark »
My daughter saw the one in the above picture and wanted one for her bedroom.
There were a ton of open paths and pretty much a mess of a file when I opened it in DE.
Prolly was program incompatibility. I Had to spend an hour or so basically redrawing it.
She loved it! Thanks for the file!
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
sonbakler
Re: Tree frog help
Post by sonbakler »
Pretty awesome tinspark! Super impressive :Like :Like
cstroke
Re: Tree frog help
Post by cstroke »
Neat file.. Thanks
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
Re: Tree frog help
tinspark wrote: Wed Apr 28, 2021 3:55 am My daughter saw the one in the above picture and wanted one for her bedroom.
Nice work Doug! I opened the original dxf file posted above with Design Edge and it did indeed have 503 unwanted intersections. I selected all and exploded "Ctrl+X" and Linked/Joined "J" using with Link Paths values set to 0.01" and .001" respectively to eliminate all the unwanted intersections. This took several minutes to accomplish. Here is the result in both dxf and pcm formats.
tree frogs rev.1 dxf.zip
tree frogs rev.1 pcm.zip
tinspark
Re: Tree frog help
Post by tinspark »
Good info David , files look clean!.
Doug,
Hypertherm 45XP-
Re: Tree frog help
tinspark wrote: Wed Apr 28, 2021 8:58 pm Good info David!. Thanks
Doug - Happy to help!
Here is a process that works for me with great success.
Before you convert to cut path I would suggest doing the following.
Step 1 - Under Settings, Offset/Convert, Link Paths set the value for "Gap distance to jump" to 0.01" and the value for "Delete overlapping segments within (inch) to 0.001".
Step 2 - Select your entire drawing and type "Ctrl+X" for Explode, then select your entire drawing again and type "J" for Link/Join.
Step 3 - Select your entire drawing and type "H" for smooth and enter a value of 0.002 and hit enter.
Step 4 - Select your entire drawing and type "D" to detect intersections. If any intersections show up, then repair them and repeat until there are no intersections.
Step 5 - Select your entire drawing and type "N" to convert to cut paths.
