Oven is home built, 4' X 4' X 8'. All metal stud construction with regular pink fiberglass insulation with the backing removed. Galvanized sheet metal and five oven elements. I may still have some construction photos if you would like to see them. I think the blast cabinet is a Skat Blast will have to look. I brought it used.
Two layer gate sign with photos of my oven build
- gblaylo
Re: Two layer gate sign
Yes - I would love to see your construction photos and also photos of your finished oven.gblaylo wrote: ↑Wed Feb 23, 2022 6:28 pmOven is home built, 4' X 4' X 8'. All metal stud construction with regular pink fiberglass insulation with the backing removed. Galvanized sheet metal and five oven elements. I may still have some construction photos if you would like to see them. I think the blast cabinet is a Skat Blast will have to look. I brought it used.
- gblaylo
I found some photos of the oven build.adbuch wrote: ↑Wed Feb 23, 2022 8:04 pmYes - I would love to see your construction photos and also photos of your finished oven.gblaylo wrote: ↑Wed Feb 23, 2022 6:28 pmOven is home built, 4' X 4' X 8'. All metal stud construction with regular pink fiberglass insulation with the backing removed. Galvanized sheet metal and five oven elements. I may still have some construction photos if you would like to see them. I think the blast cabinet is a Skat Blast will have to look. I brought it used.
- gblaylo
Re: Two layer gate sign with photos of my oven build
Amazing oven build! Absolutely fantastic and I appreciate all the pics, that's awesome.
