Kubota L2501 Grill Guard File
Was wondering if anyone had a file to cut a grill guard out for a Kubota L2501 Tractor
Re: Kubota L2501 Grill Guard File
Are you looking for the insert, like this?
J-Sig That is what i am looking for.
Not looking for one but that sure is pretty
nice work
nice work
Hypertherm 65
Hypertherm 65
Super cool Jeff, looks awesome
Not a current design I have! Pic is from online, but would be an easy one to do if I had the dimensions I needed for the O.D. of insert! I did one of an older model for a friends L5740 but not sure how close yours is! If you did an outer border it would be easy to make! Just add some bend lines after the slots and holes and go for it!
Would be glad to help!
thats a good idea
I sure like the looks of that orange one! Nice find Jeff. As you mention, once you have the dimensions for the outline - the rest is "cake".
- ben de lappe
I drew this from pics to client specs a few years ago, didn't hear back but 'assume' it fits well. If it helps you're welcome to it. Overall 21"x25.2" with mounting tabs.
Wow Ben, looks great! Thanks for sharing.
ben de lappe Thanks for the share i will see if this will work on my Kubota L 2501
- ben de lappe
Thank you Newb!
You are most welcome and I look forward to an update.
Very nicely done Ben! I hope the OP can use it.
- ben de lappe
Thank you very much and that's two of us. Should be close if not exact. Certainly the best I could do from a pic and the dimensions he supplied. Worst case scenario I figure keep the interior and modify the profile/tabs if necessary.
I must admit to a slight bit of jealousy as my little BX 2350 D can't use it.
- ben de lappe
I completely forgot about this image showing the supplied dimensions this piece was draw to. Maybe it'll help in this process.
Here is a grill I designed for my Kubota L2501. If you use this design, check the measurements to what your tractor needs and adjust to your needs. I used automobile undercoating to paint this grill since I had no access to powder coating.
I like it!
Hope you share a finished pic
of it on your tractor!
That looks great! Nice job. I too hope to see the finished product photos.
Here is the actual cut grill haven't had the chance to install it on the tractor yet.will post those pictures when I get it installed.
This looks very nice! Thanks for sharing your finished part.
Looks Great!
The undercoating will give a tough finish
and be easier to touch up if it gets scratched!
Thats a pretty sweet looking grill! Well done
Wow. That looks familiar.
Ben, this looks amazing! I'm going to modify this file to fit a 2601. Thanks for the share, if I can make it work, I'll share it on here!ben de lappe wrote: ↑Fri Mar 03, 2023 11:36 am I completely forgot about this image showing the supplied dimensions this piece was draw to. Maybe it'll help in this process.
Matt
