Hypertherm Edge THC problem
rick_b
Post by rick_b »
I have a problem with the THC on my new plasma that no one seems to be able to fix. When the sheet bows up the torch follows it up with no problems but when it clears the bow it takes way too long for it to come back down to cut height which means it will not cut the sheet.
Re: THC problem
Please tell us more about your table, thc, and software. What kind of table, thc, and control software.
rick_b
Re: THC problem
Post by rick_b »
Hypertherm powermax 105 sync, Hypertherm EDGE Connect controller with Hypertherm phoenix software, Hypertherm THC, Pronest LT nesting software on a Loyalmak 4020 table.
Re: THC problem
Rick - I don't know anything about the Hypertherm Phoenix software, but I expect there may be some height control adjustment settings available in your control software. For my Plasmacam Design Edge software, there are settings available for max climb rate and max dive rate. If you have these, then try increasing your max dive rate.
rick_b
Re: THC problem
Post by rick_b »
Interesting, I will have to have a looking and see if I have anything like that.
Re: THC problem
If you've got some settings pages, maybe post some screen shots so we can have a look.
