welding squares
mtvet06
welding squares
Post by mtvet06 »
Good evening,
I am curious if anyone has any welding square cut files?
Zach
tinspark
Re: welding squares
Post by tinspark »
mtvet06 wrote: Thu Mar 07, 2024 12:02 am Good evening,
Zach
Hey Zack,
Here are a few. I have made a few of these and love them!!
Welding Squares.dxf
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
DieselFumes
Re: welding squares
Post by DieselFumes »
Super cool. thanks Doug! Any tips on anything special you do to finish them after welding if they need to be trued up?
tinspark
Re: welding squares
Post by tinspark »
They seem to fit together well.
I made a few of these a couple of years ago, but nothing sticks out in my memory as a problem, which I usually do remember those to elf correct if possible. .
I remember doing some grinding on the high spots that stick up after welding so that all surfaces are flat.
I have used them several times.
The large width of the squares makes them square both ways which comes in handy
Doug,
Hypertherm 45XP-
mtvet06
Re: welding squares
Post by mtvet06 »
Thank you! Exactly what I was looking for!!
Zach
Re: welding squares
Nice design Doug. I opened the file with Design Edge and did find a few minor issues. Here is the edited file.
Welding Squares rev.1.dxf
tinspark
Re: welding squares
Post by tinspark »
adbuch wrote: Thu Mar 07, 2024 5:50 pm Nice design Doug. I opened the file with Design Edge and did find a few minor issues. Here is the edited file.
Thanks David, but cant take credit for them . not my drawings. I just saved them and burned a few of them some time ago. I think I cleaned my PCM file after downloading it into DesignEdge but never exported back as a clean DXF and forgot that there were any issues. Thanks for fixing
Doug,
Hypertherm 45XP-
tinspark
Re: welding squares
Post by tinspark »
Thanks David, but cant take credit for them. not my drawings. But they do work really well.
They definitely are no machinist squares, but work great for the welding shop.
I just saved them and burned a few of them some time ago. I think I cleaned my PCM file after downloading it into DesignEdge in my shop, but never exported back as a clean DXF and forgot that there were any issues. I do not have DesignEdge on my office PC and access DXF files through cloud services, which is where I save stuff and share when others have a request,,
Thanks for fixing
Edit: I just overwrote the prior welding square DXF file with the "few minor issues" with the one that you cleaned up. Thanks again David.
Doug
Doug,
Hypertherm 45XP-
Re: welding squares
Me me Me attach them here please :Like :Yay
Re: welding squares
acourtjester wrote: Sat Mar 09, 2024 8:54 pm Me me Me attach them here please :Like :Yay
Tom - do you need the file? i attached it to my previous reply. Are you not able to download it?
Re: welding squares
I did no understand that was the corrected file Thanks for pointing that out :HaHa
Re: welding squares
acourtjester wrote: Sun Mar 10, 2024 9:53 am I did no understand that was the corrected file Thanks for pointing that out :HaHa
:Like :Like :Like
Osborn89
Re: welding squares
Post by Osborn89 »
Thanks! I'm going to cut some out and have students weld them together next week. Hopefully they turn out well enough they can use them for future projects
Re: welding squares
Osborn89 wrote: Wed Mar 13, 2024 9:59 am Thanks! I'm going to cut some out and have students weld them together next week. Hopefully they turn out well enough they can use them for future projects
These will make great student projects! Let us know how they turn out.
Scratch
Re: welding squares
Post by Scratch »
That’s a great idea! Something they can keep and use their whole life!
mtvet06
Re: welding squares
Post by mtvet06 »
I think that is an awesome idea!
SeanP
Re: welding squares
Post by SeanP »
This is another alternative I came up with, they work really well and you have cutouts to get clamps in, I lightly tig welded the tab n slots.
6mm 2pcs Square P2.DXF
6mm 1pcs Square P1.DXF
6mm 1pcs Square P3.DXF
Jason@bc
Re: welding squares
Post by Jason@bc »
Thanks Sean, I just built myself another set just a few weeks ago, but these look a little more compact, I'll sure try em'. Can never have enough welders helpers/gadgets/etc...in a welding shop.
mtvet06
Re: welding squares
Post by mtvet06 »
SeanP wrote: Thu Mar 14, 2024 12:50 pm This is another alternative I came up with, they work really well and you have cutouts to get clamps in, I lightly tig welded the tab n slots.
Thank you Sean! I appericate it.
