Tom - I agree! Lots of weight cantilevered out there with not much support. If he can grab the torch with his hand and wiggle it (it has movement) then that could be a problem. You want your torch nice and tight. Also check the entire machine by grabbing the axis and trying to move them by hand with the system powered up. There should be no detectable movement at all.acourtjester wrote: Wed Aug 14, 2024 10:18 pm I agree with TJ I have attached one image with things that could be changed to help. The torch mount is way to long and the lower part looks like a floating head assembly. If the blue section is repositioned down and the torch holder shortened it may help. The single linear rail that is used on the torch holder may not be steady enough. Her is another view from their YouTube post and the torch holder is positioned much shorter, it may be a newer design.
