Cancer Fundraiser
cutnweld
Cancer Fundraiser
Post by cutnweld »
Hello everyone, I am looking for ideas of what to make to donate for a fundraiser for a neighbor who has been on a long downhill battle with cancer. Just looking for ideas, what is meaningful, etc.
cuttinparts
Re: Cancer Fundraiser
Post by cuttinparts »
I used the search feature and came up with quite a few ideas from other members here.
Hopefully this gets you onto something that interests you.
viewtopic.php?t=36120
viewtopic.php?t=7240
viewtopic.php?t=21516
viewtopic.php?t=20089
viewtopic.php?t=12946
viewtopic.php?t=30480
viewtopic.php?t=9561
cutnweld
Post by cutnweld »
Metal bench welded.svg
Thanks. I took the butterfly and put it into this bench. Look OK?
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Ermaksan Brake
Nice job cutnweld! One thing you might consider is to take the outer shape segments of the butterfly and "stroke to path" to widen out those path segments for better visibility.
Bench with Butterfly.svg
cutnweld
Post by cutnweld »
Thanks Adbuch, I was workiing a bought and downloaded file, I was having lots of grief working with it I didnt know about the join node function, thanks a lot that helps!
10x40 lathe
2-Miller 255
Miller XMT350MPA
Cutnweld - It seems that many of these purchased downloads have this problem with the disconnected path segments. I only know this because I have helped other in the past with similar files. Here is the generic file without the butterfly added, just in case you wish to try some different things with it in the future. Let us know how your bench turns out.
generic bench file.svg
cuttinparts
Nice! Looks great guys. Post a pic when you get it built, would love to see it.
cutnweld
Post by cutnweld »
Thanks David. I actually put the butterfly in for the cancer ribbon on it. Does it not fit? I am open to ideas
10x40 lathe
2-Miller 255
Miller XMT350MPA
cutnweld wrote: Thu Aug 22, 2024 11:12 am Thanks David. I actually put the butterfly in for the cancer ribbon on it. Does it not fit? I am open to ideas
The butterfly fits perfectly!! I had assumed that you purchased the file with the center area blank and then added the butterfly. So I was just posting what I thought you had started with - but edited to link/join it to eliminate all of those disconnected path segments. In any case, I think your bench is much more attractive with the butterfly than a cancer ribbon.
