Cutting with common line
Mayle1994
Post by Mayle1994 »
Hi, im trying to cut an entire plate using the common line with cnc xpr300 but the hole is not coming up in the middle of the plate.
Can you help me??? Why is this happening??
Re: Cutting with common line
Please post your dxf file.
You could be losing some positioning if the file checks out ok. I used to run my rapids as fast as they would go and that got me into trouble with losing steps and being off position. Do you run your rapids really fast?
68rscamaro
Post by 68rscamaro »
Lets see your dxf file
I'm guessing it's not offsetting for the kerf width correctly
