I found an adapter at https://www.thingiverse.com/thing:5422309 that allows for the use of a short 7mm pencil (like you get at the golf course or from catalogue stores to fill out forms) in place of a Sharpie pen and it works great. Also, 8mm hex and round pencil adapters.
The tolerances are very close so I had to spend a quick minute with a fine file both inside and outside of the adapter to get it to slide perfectly.
Pencil Adapter for a Sharpie holder STL
- jmersereau
PrimeWeld CUT60
Langmuir CrossFire Pro
Re: Pencil Adapter for a Sharpie holder STL
Cool, thanks. Another tool that would be great. Hopefully my buddy can print one of these for me as well.
I assume that this will not be using the spring, but is a snug fit for the adapter.??
- jmersereau
You are right it does not use the spring in the holder. Yes, it is a snug fit.acourtjester wrote: Sun Jan 05, 2025 11:24 am I assume that this will not be using the spring, but is a snug fit for the adapter.??
I showed it in "my" CNC Sharpie adapter as a test fit. I was providing for the other designs that use Sharpies with floating mounts.
PrimeWeld CUT60
Understand thanks
