Badges
- GoingCustom
Badges
Been quite a while since I've posted on the forum, but still doing metal work nonetheless. Some recent badges I made for a customer. Mix of cnc plasma, scribe, laser engraving, steel dye, clear coat, vinyl and epoxy.
Travis
one of a kind gates, fine art and CNC designs
- GoingCustom
Re: Badges
Pic of what's in the video
Travis
- Joe Jones
Re: Badges
Wow! You are where I want to be! AWESOME work!GoingCustom wrote: Thu Feb 20, 2025 4:43 pm Been quite a while since I've posted on the forum, but still doing metal work nonetheless. Some recent badges I made for a customer. Mix of cnc plasma, scribe, laser engraving, steel dye, clear coat, vinyl and epoxy.
- GoingCustom
Re: Badges
Thank you! Lots of trial and error and figuring stuff out over the years! As with a lot finished projects, there are usually some "how do I fix this" moments along the way!Joe Jones wrote: Thu Feb 20, 2025 7:46 pmWow! You are where I want to be! AWESOME work!GoingCustom wrote: Thu Feb 20, 2025 4:43 pm Been quite a while since I've posted on the forum, but still doing metal work nonetheless. Some recent badges I made for a customer. Mix of cnc plasma, scribe, laser engraving, steel dye, clear coat, vinyl and epoxy.
Travis
Re: Badges
Very nicely done! There was a member a short while ago wanting to make a USMS (United States Marshal Service) badge very similar to the one you made. I think I suggested that he might consider engraving/scribing the center portion very much like you have done.
Thanks for sharing your work with us.
Re: Badges
very nice the epoxy give them a excellent finish, and make them POP.
Is you scribe air powered or an easy scribe???
what epoxy did you use the did not effect the vinyl?
- GoingCustom
Re: Badges
Thank you! I'll keep an eye out for his post!adbuch wrote: Fri Feb 21, 2025 2:24 am Very nicely done! There was a member a short while ago wanting to make a USMS (United States Marshal Service) badge very similar to the one you made. I think I suggested that he might consider engraving/scribing the center portion very much like you have done.
Travis
- GoingCustom
Re: Badges
Thank you! It's a pneumatic scribe that came with the table. It's a marine grade epoxy that I picked up from a local wood working shop. When I get back to the shop I'll check the brand.acourtjester wrote: Fri Feb 21, 2025 3:43 pm very nice the epoxy give them a excellent finish, and make them POP.![]()
Travis
Re: Badges
Wow! The picture doesn't do them justice, have to watch the video to fully appreciate these. Amazing work!
