messer hpr260
messer hpr260
hi all . i bought used table messer hpr260 for really good price and comes with cutter hypertherm hpr260 but im small shop and i dont have enough power only 150amp 460 for whole shop .i already own powermax 125 cutter it is possible to connect this cutter to the table? i apologize for my language but im from europe and still learning .thank u
Re: messer hpr260
Absolutely you can connect your Powermax 125 to your table. Does your 125 have the CNC interface card? You don't need to have it to connect the 125 to your table but it does make it easier and will provide you with a divided voltage signal for your auto torch height control if it requires divided arc voltage to operate.
Re: messer hpr260
yes it has cnc port on back currently working with crossfire xr. any idea where ishould start>?any help really appreciated
Re: messer hpr260
If your Messer table has no THC you only need to hook up the 2 wires to trigger the plasma on and off and that will be super easy but I do not know where those connections would be in your Messer controller. Should be easy to track that down. Does your Messer table have a THC?
Re: messer hpr260
yes it has i will snap few photos tomorrow its so many boxes i cant event find out
- SegoMan DeSigns
Re: messer hpr260
125 amps on either machine will have similar draw (31 amps / 480v as per hypertherm) it is when you crank the amps up for thicker metal that the 260 can go to 60 amps / 480v draw
I would leave it as is and save your thick cuts when other hi draw machines are off line
