Hi Everyone,
This is a great site. I've made quite a few of the files posted on this site.
I'll post some pictures soon. I'm looking for files for a wheelbarrow that could be
welded together to put flowers in. Thanks
Wheelbarrow
Re: Wheelbarrow
Hi, about how big should the Wheelbarrow be?
Pat
Pat
Re: Wheelbarrow
It will end up being about 20-24" long. Looking for a decorative wheelbarrow. I'll size it so it could be for
in the house or out side. Thanks
- Loyd
Re: Wheelbarrow
Hello,
Here is my attempt at a wheelbarrow planter. You will need to put a expanded mesh bottom or slats. My idea is to bend the supports above the wheel and above
the vertical rear supports to be parallel with the centerline of the planter box. This would make the box supports in the shape of a V when looking at the top view. You would need two of everything except maybe the wheel.
For what it is worth here it is.
Loyd
Loyd
Re: Wheelbarrow
Hello, I drew a wheelbarrow that could be cut and welded together. Ionly drew the side view of which two piece's would need to be cut. And I drew a wheel. Depending on how wide the wheelbarrow is needed, you would then cut out a rectangular piece for the front, and a piece for the back, and a piece for the bottom and weld everything together. If you have a metal ring roller, you could cut 2 wheel pieces, space them apart a little, and then weld a ring around them. A piece of 1/2' round bar is needed for the axle.
Pat
Pat
Re: Wheelbarrow
Thanks everyone, this will get me started.
