The torch height is very easy to use, the reason we say 1/8" is to get people started and less likely to hit the pierce point slag.
BurnTables THC:
Read the THC instructions carefully. After reading the instructions, view this video for more info on the THC
http://www.youtube.com/watch?v=0gd2Kd7AObA
?Pierce Delay? has 4 settings: Off, .05 seconds, 1 second, 1.5 seconds. Pierce Delay is the time the machine pauses before it starts its motion after it fires the torch.
IMPORTANT Adjust the pierce height before cutting out a part. To set this correctly, the plasma power supply needs to be ?Off? and the THC in the control software to be ?ON?. Load the test G-code file and press ?Cycle Start?. Let the torch touch the material then rise up until it stops. The reading in the z axis digital read out window will be the ?Pierce height?. If this is not correct, adjust the knob Counterclockwise (-) or clockwise (+) in small increments and then press ?stop? and ?rewind G-code?. Press ?cycle start? again until the correct height is achieved.
Set the ?Anti Dive? setting in the BurnTables program to 110 (under the THC button). This will get you started in cutting small pieces. Before moving to larger pieces, read and calibrate the Torch Height detailed below. Also understand how the Anti Dive setting works (covered later in the manual). Make sure feed rate for the thickness of material is correct (SheetCAM), if you are going too fast or too slow. This will affect the THC.
THC Calibration (cutting larger pieces):
Set the anti dive speed to 85 and load the test .tap file.
The Torch Height Control works like a cruise control in a car. Set the height via the Torch Height knob to a set height and the THC keeps that set height when cutting, similar to setting the speed on the cruise control. THC will maintain that height, while materials warp form heat. Only adjust the Torch Height knob when cutting straight lines! This is when the speed of the machine is above the Anti Dive speed and is taking input from the THC. A good starting point for the Torch Height knob is to turn the knob all the way clockwise, then back it off counter clockwise an 1/8 of a turn. If the torch is too low while
24
cutting a straight line, turn the torch height knob clock wise to raise the torch. Counter clock wise will lower the torch. The torch should be about an 1/8 inch above the material while cutting.
The Torch Height will periodically need to be adjusted to compensate for wear in the consumable. The THC has a delayed response so it will take some time to react to you turning the knob. Once the sweet spot is found, it is very sensitive. Small inputs will greatly affect changes to the height of the torch.
Video on how to set up the THC
Make sure the Plasma Cutter is on the expandable metal setting and the amperage of the machine matches the consumables in the torch. If the torch stops cutting and the machine stops running, check the plasma for fault codes.
