40 amp nozel
55 ipm
156 V
2 seperate issues
49 ipm is what the book suggests for the .25, I will slow my speed down the next time I cut but was wondering if the speed is the problem here?
On the cuts you can see where the cut bumps out at the diamond.
I have the same issue with .125 diamond plate as well and it will leave a little dross by each diamond or on the one edge which is a bear to try and clean if the customer wants polished diamond plate for the sign.. If I cut the .125 with a fine cut tip at a slower speed then I don't have the issue..
I'm assuming the answer is to slow down a little but want to be sure there are no other issues here..
Thanks gang
