new to sheetcam
1347CS
new to sheetcam
Post by 1347CS »
I have sheet cam an I have been tring to figure the machine settings and material thickness can anyone help me.
Capstone
Re: new to sheetcam
Post by Capstone »
There were more than 1600 hits on youtube using sheetcam as the keyword. I suggest you start there, that or RTFM. :o
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
pertneer
Re: new to sheetcam
Post by pertneer »
For machine settings:
Machine type tab
  • Jet cutting = plasma/laser/waterjet
  • Rotary = router/mill
Post processor tab
  • inch/metric Your choice
  • post processor depends on your machine
    example
    • CandCNC use their specific post processors
    • Plasmacam use the plasmacam post processor
    • etc...
Working envelope
give the travel of your x and y axis with the zero of your machine specified for origin (usually bottom left so all numbers will be positive numbers)
Table display
not needed just shows you table outside of travel
save/load
Here you can save your settings in case you change computers at a later date
The result of these settings
4'x8' CNC Plasma w/Water Table Running a Powermax 65 :D
CandCNC, Mach3, SheetCam, Millwrite Plasma V6
1347CS
Re: new to sheetcam
Post by 1347CS »
thank you is this my table size
pertneer
Re: new to sheetcam
Post by pertneer »
They were just examples. Just measure travel in both axis and input those numbers as you table size.
abmagrum
Re: new to sheetcam
Post by abmagrum »
check this out http://arclightcnc.com/training.html
click setting up sheet cam
see if this helps
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Return to “SheetCam”
