I have built all my equipment, except for the powder gun. I am using an Eastwood Hot Coat 1100 Pro. I dont think that they make it anymore but it has been a great gun. I got it used about a year ago. I like it because it has adjustable KVs. This will help you in coating areas that may have a faraday effect. Like inside corners and pieces that are parallel to each other. Also helps in doing multiple coats or colors. I have done 4 coats cold with this gun. Clean up is easy with this gun also. Can change colors in less than a minute. I have changed out colors more than 30 times in one day! I have used this gun to coat metal, wood and glass, as well as a few other things that should not be able to be coated. I am saving my money to get one from Columbia Coatings, the Kool Koat 3.0 with DPW. Should be the last gun I ever buy.
As for my spray booth, I have made my own, it is not the greatest but it works for me, for the most part. I used 4x8 sheets of white board from lowes, I cut a hole in the back wall and have 2 20x20 air filters in it. I can remove them and tap them out in the trash can to get most of the powder out of them. Then I hit them with the air blower and get the rest out. They work for about 2 or 3 uses and then have to get new ones. I mounted a whole house attic exhaust fan on the back side of my booth to pull the air through.
As far as the oven goes, check Craigslist for broken ones. You can start with that and get going. Cut the top out of it and make new sides and you can create a larger oven on a budget. I started that way but very quickly found that it was too small so I built my own oven. inside dimensions are 4x4x7'6". I use 4 3000 watt oven elements. Got the elements and the controller from
http://www.tccoatings.com. He also sells some good powder.
As far as the harbor freight one goes, save your money. I have one. Used it a few times and said screw this and bought the Eastwood gun. The harbor freight gun will shock the piss out of you if you touch the part while spraying. The Eastwood gun grounds you out so that you can touch the part. For powder, I use Columbia Coatings or Prismatic Powders. I have bought powder from at least 10 different places but like these 2 places because of their turn around time and customer services.Ill attach somepictures of my setup. Not pretty by any means but it gets the job done. I need to do a good cleaning on my spray booth and replace the filters. I have been coating the hell out of some parts for a show that I am doing that lasts 5 weeks. Pretty much have to replace my inventory 2 times a week. Its a long show but usually pretty good. Did almost 6K in 5 weeks last year. If you have any questions about powder coating give me a yell and I will try to help you out.
![Image](http://i988.photobucket.com/albums/af2/QuietCreekServices/Mobile%20Uploads/20131211_101539_zpss7mx0gs0.jpg)
