My TM3 started acting up today....the Y axis would only jog to the +, .......even when clicking on the -. The motor went + no matter which way I told it to go. I reset the controllers, checked the wiring and it worked ok for a little bit, so I tried cutting a small piece, and about half way through, it took off the wrong way again. In the middle of cutting a hole, it took off and the cut ended up looking like an "S". So I wiggled the wires and checked everything I could think of and tried again, then when jogging the other axis that had been working ok, it started growling and stopped after moving a few inches.
Anybody have any ideas, other than the controller it toast?
Torchmate axis motor only goes +
- _Ogre
Re: Torchmate axis motor only goes +
tm tech support would be able to help you trouble shoot that
an ogre smiley
how cool!
an ogre smiley
Yes, and they have always been very good......but they aren't there on the weekend._Ogre wrote:tm tech support would be able to help you trouble shoot that
