measuring on plasma cam dhc2
Rockenjvdesign
Post by Rockenjvdesign »
This is weird but has anyone ever typed in say 10.375 and it makes it 10.401 instead? How do you fix this? I'm trying to make some stuff that needs to be right on the money thanks in advance :?:
Rocken JV Design We do it all
Plasma cam DHC2
hypertherm powermax 45
Custom furniture
Home décor
icmplasma85
Re: measuring on plasma cam dhc2
Post by icmplasma85 »
Thats strange, never had that happen, but try drawing a line any length and offsetting that line 10.375 (when offsetting hold ctrl while you click on first line to offset so it leaves original line as well) then connect the two with a line and see if it gives you the correct measurement.
PlasmaCam DHC2
Hypertherm Powermax 65
Millermatic 211 MIG Welder
Rockenjvdesign
It even cuts it out smaller I can even take something that is drawn up and scale it to a certain me sur mesurment and it is still off
Plasma cam DHC2
Custom furniture
Home décor
icmplasma85
So is it measuring different on the screen or when you cut?? If you are drawing something 10.375 and it cuts it bigger, you need to change your offset for converting cut paths to a different number. What do you have for your kerf offset number?
PlasmaCam DHC2
weldor2005
Post by weldor2005 »
I dont know if this has anything at all to do with it, but try and see if it is trying some node snap or something. Mess with your general snap settings, like turn them all off and see if it will give you what you want then.
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Dan-PlasmaCAM
Post by Dan-PlasmaCAM »
Do you have snap to grid checked? This is probably what is going on.
Rockenjvdesign
Yes. I do
Plasma cam DHC2
Custom furniture
Home décor
weldor2005
Rockenjvdesign wrote:Yes. I do
So, does turning them off fix it?
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Rockenjvdesign
No I just have to draw every line but Idk what to do when I bring in a dfx it will just be off a little
Plasma cam DHC2
Custom furniture
Home décor
Dan-PlasmaCAM
Does it measure wrong in the program or does it cut wrong?
Rockenjvdesign
It is the program that is wrong
Plasma cam DHC2
Custom furniture
Home décor
Dan-PlasmaCAM
And removing snap to grid does not fix it?
Rockenjvdesign
No sir
Plasma cam DHC2
Custom furniture
Home décor
weldor2005
I may be grasping at straws as it has been a while since I dealt with DE lately, but I would maticulousely check that all the settings in the design page are correct.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Email me a copy of your plasmacam file (ready to cut) for the part you are having an issue with. Let me know what you have set in your software for width of cut (kerf), and what material type and thickness, as well as what nozzle and power level you are using. I'll put it in my Design Edge and check it out to see what is going wrong.
Jim Colt jim.colt@hypertherm.com
weldor2005
jimcolt wrote:Email me a copy of your plasmacam file (ready to cut) for the part you are having an issue with. Let me know what you have set in your software for width of cut (kerf), and what material type and thickness, as well as what nozzle and power level you are using. I'll put it in my Design Edge and check it out to see what is going wrong.
Off Topic...
If our Politicians were as responsive and helpful as JIM, the USA would be in a lot better shape.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Rockenjvdesign
Ok I will Jim it will be later in the day today ie I got to go to the paying job first
Plasma cam DHC2
Custom furniture
Home décor
