export Vector files???
ok ! so im over run with playing catch up in the softwear side of art and a buddy hits me with all this different stuff he exports for vector art and im lost! can the spider family tell me what terms work and whats transferable to use? DXF Line/ Poly Arc/ Poly Line/ Spilned Line? if someone can tell me where these terms fall into what we use daily for art to transfer to plasma dxf cutable id really enjoy the help! thanks in advanced, Kyle
Re: export Vector files???
Are you using Coreldraw ?
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Beffy, the buddy has a vinyl grafics shop, there soft wear is a little different then ours. I don't have Corel or I Probly wouldn't have been so vague with what I was asking. I'm just trying to cut stuff for him in metal that he has designed and find common ground in soft wear that we both understand. Thanks hooked!beefy wrote:Are you using Coreldraw ?
If it is a vector.....Inkscape will open most any file type. (ai, eps, svg, pdf, etc...) Then you can save as dxf or svg and go to sheetcam. If I understand what you are asking then that should do it.
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
