Backward Cuts
KIDTech
Backward Cuts
Post by KIDTech »
Everything looks good on the screens from ACAD to SheetCam to Mach3 but when the table is running it cuts backward. Meaning if you look at the letters from laying on your back on the floor looking at the underside of the piece the letters are correct. I hope this makes sense and appreciate any help offered. I plan on this weekend to reverse the x-axis motors from how they are currently set.
Re: Backward Cuts
Post by tnbndr »
Have you seen this post?
Is this something that just started happening?
http://www.plasmaspider.com/viewtopic.php?f=55&t=14657
KIDTech
Re: Backward Cuts
Post by KIDTech »
Haha well now I feel a little lazy for not reading the post directly below mine! Sorry guys for the multiple posts. I have been doing a lot of research but have not had the chance to check anything as of yet. Most of the responses seem to be to switch the direction of the x-axis motors and see if that fixes the issue. I've also seen where the CAM software and the CNC software have different ideas as to how the table is set up, where 0,0 is and so on. I will let you know as to what I find and get back with you. I too recently moved my machine and wonder if I did not connect the motors back the way they should be.
KIDTech
Re: Backward Cuts
Post by KIDTech »
Just a little follow up, switching the direction of the x axis solved my issue.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
Return to “Mach3 & Mach4 CNC”
