This is still happening and I am not sure why. The cuts start well and look good but there will be usually one spot where it stops cutting for a bit. My air pressure is good as is my air is clean and dry. Any help would be greatly appreciated and to point out it starts about the mouth and works toward the belly. I also noticed an odd "wobbly" cut on the end of the opener and discovered my y-axis to have a little play in it so that is fixed.
DIY 5x10 table with Longevity ForceCut 42i
G540
ACAD
SheetCam
Mach3
Cuts Fail
Cuts Fail
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
Gecko g540
Proma THC
Millermatic 211
Re: Cuts Fail
A little more information is needed to help much. Do you have your ground attached directly to your sheet? Do you have a THC? What are the cut parameters you are using for this cut? Almost forgot, what is the material gauge?
5 x 10 Air bladder water table
Precision plasma HDB gantry
CandCnC 620-4 Bladerunner
Feather touch ohmic plate sensing
Hypertherm Powermax 65
2015 Autocad lt
Mach 3
Central California
2015 Autocad lt
Mach 3
Central California
Re: Cuts Fail
Ground is directly attached, THC won't work still. Bought a Proma but can't even get it to read the voltage and 1/4" material. I slowed it down and it cut through so hopefully that was the issue. Just find it weird that it matters since it cut most of it out until the tail end.
Gecko g540
Proma THC
Millermatic 211
Gecko g540
Proma THC
Millermatic 211
Re: Cuts Fail
Here it is finally, thanks for
the help.DIY 5x10 v rail, rack and pinion
Gecko g540
Proma THC
Millermatic 211
Gecko g540
Proma THC
Millermatic 211
- tnbndr
Re: Cuts Fail
When that happens to me usually it is the electrode or nozzle failing.
I think that moisture will also cause this to happen.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
- ben de lappe
Re: Cuts Fail
Moisture will cause skips as evident. I had the same problem, it took a long time for problem to manifest. Once air filtration was improved the issue was alleviated.
