GARY FOSTER
Post by GARY FOSTER »
Any idea why when I import files and convert to cut path the lines look like this above....New to this and not sure if I am doing something wrong.
wilber
Re: -------------
Post by wilber »
If i got something like that i would think that there was way to many nodes.
gs123
Re: -------------
Post by gs123 »
it looks like your importing a cut path instead of a complete dxf drawing.
a cut path has broken lines in it somewhere and you will see dashed lines anytime you have a broken line.
thats what i get in torchmate cad anyway. hope this helps.
CNCCAJUN
Re: -------------
Post by CNCCAJUN »
If it does it on everything you import it has to be a setting in the software you are using . . .
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
illusivedf
Re: -------------
Post by illusivedf »
If I was doing an autocad drawing I would use a dashed line on a separate layer for hidden lines. Or if it is a bunch of points in autocad you can try command overkill to clean it up some.
Owner at Illusive Design & Fabrications
http://www.illusivefabrications.com
Air Ride Suspension Parts
Metal Fabrication
Dynatorch 4x8 with Hypertherm 1250
Vinyl Decals & Signs
Powder Coating
Re: -------------
Post by tnbndr »
Check the linetype of the layer you are creating the item on. It may look solid in CAD due to the linetype scale factor but show as the actual linetype in SheetCam or whatever program you are importing it into.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
_Ogre
Re: -------------
Post by _Ogre »
what cad and what cam software?
