Expanding my setup
wickedinhere
Re: Expanding my setup
Post by wickedinhere »
Here are the oven build pics.
wickedinhere
wickedinhere
wickedinhere
wickedinhere
sodfarmer
Post by sodfarmer »
Would you mind sharing where you purchased your fan and the PN#? Thanks
wickedinhere
I got it at graingers and its a Dayton 1TDU9 High Temperature Blower, 115 Volt, 76 CFM some people use higher cfm fans but this one is perfect.
frodin1
Post by frodin1 »
What did you end up using inside the walls as insulation? Is that just OSB or expanding foam, kind of hard to tell from pics?
wickedinhere
Mineral wool
alleykat
Post by alleykat »
I would like to make a bigger oven than I already have but I dont know if I should mess with wiring. :P
PlasmaRoute Blaze HD 4x4
Thermal Dynamics Cutmaster A60
Copp3r
Post by Copp3r »
Great looking oven... To each his own, and certainly I am biased but I prefer my roll in / flat bottom to the idea of having the oven on wheels. There are pro's and con's to each. I don't see the need to move the oven... ... and I have a rack that I hang my projects from, apply the powder coat and then wheel the rack right in to the oven. When the baking portion is over and done with, I merely roll out the rack.
Thanks for the images on the application booth. You must have been reading my mind. I've got a new shop underway and one of the items I want to built is a place to apply the powder coats. Without a booth the powder goes everywhere.
Thx
Copp3r / roger
wickedinhere
Thanks, a rack system would be nice.
SeanP
Post by SeanP »
Nice Job!
Can I just ask what the total wattage of the elements are?
Do you find them about right for that size of oven?
Sean
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
wickedinhere
12000 total watts it works great great recovery time when opening the door.
SeanP
Post by SeanP »
Good stuff, thanks
Powermax XP45
Table build gallery
radnurse68
Post by radnurse68 »
Do you mind sharing your cost on your oven build? There is an used oven nearby for sale that is the same deminsions as yours. It is several years old and has been setting outside in the weather for a year or so. The current owner has never fired it up but says he will guaranty that it works for $1500 and will sell at $1000 without the guaranty.
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
wickedinhere
I have around 16-1800 in it.
CNCCAJUN
Post by CNCCAJUN »
wickedinhere wrote:Thanks, it hits 400 in 17 minutes I will post pics of my booth when i start.
Have you calculated a cost per hour for your oven yet . . .?
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
wickedinhere
I have not but it doesn't it doesn't cost that much to run. I don't run it all day but when i do run it its for a few hours at a time. I try to get 5 or 6 pieces lined up to powder coat at one time so i am not just doing one item at a time.
Return to “Powder Coat”
