Over burn
Biker
Over burn
Post by Biker »
How do you program an over burn in sheetcam. I'm missing something here.
CandCNC Blade Runner Dragon cut 620 Ethercut + DTHCIV
Precision Plasma 5 X 10
Mach 3
Hypertherm Powermax 85
dhelfter
Re: Over burn
Post by dhelfter »
when you create your jet cutting operation. It is called overcut. If it is not available you may need to get the newest stable version of sheetcam.
Dan
LDR
Re: Over burn
Post by tnbndr »
Dan:
Is it in this window?
I don't have that option and would like to experiment with that setting to get rid of the divot.
What is the latest version that is stable?
Jet Tool.jpg (37.42 KiB) Viewed 1486 times
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Re: Over burn
it is in the operations menu
here shown in the jet cutter center of menu.
dhelfter
Re: Over burn
Post by dhelfter »
Sent you an email
Dan
LDR
Biker
Re: Over burn
Post by Biker »
Acourtjester,
I see the over cut section now. Thank you so much.
Mach 3
Re: Over burn
Post by tnbndr »
Loaded the latest update and now have that option.
Thanks for everyones help.
