nest question
kbenz
nest question
Post by kbenz »
I know the nesting isn't really nesting. I know how to array and duplicate parts. I have not figured out how to rotate them though. also can you add other parts to manually nest? should I just do this in my cad program?
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
I Lean
Re: nest question
Post by I Lean »
With the part highlighted, just type in a rotational angle in the box at the bottom right of the screen. Example, put in 10, it will rotate 10 degrees clockwise. -10 will rotate counterclockwise.
To add other parts, just go to File -> new part, then import another drawing. You can have as many individual parts as you care to add. Each one will need its own operation though. (as opposed to duplicating a part, which uses the same operation as the original)
kbenz
Re: nest question
Post by kbenz »
I Lean wrote:With the part highlighted, just type in a rotational angle in the box at the bottom right of the screen. Example, put in 10, it will rotate 10 degrees clockwise. -10 will rotate counterclockwise.
perfect,,, thanks :mrgreen:
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
kbenz
Re: nest question
Post by kbenz »
do you nest all your parts then assign cut paths, or do it as you import? If you do a certain part often, can you save the .tap files and import them as needed? or need to assign cut lines everytime?
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
beefy
Re: nest question
Post by beefy »
A lot of people don't know about the < and > buttons to rotate parts. I certainly had a yippee moment when I found out about them.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
kbenz
Re: nest question
Post by kbenz »
beefy wrote:A lot of people don't know about the < and > buttons to rotate parts. I certainly had a yippee moment when I found out about them.
Keith.
Thanks for that Keith. Thats a whole lot easier. Definitely a yippee moment.. :mrgreen:
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
I Lean
Re: nest question
Post by I Lean »
Keith.
Yippee! :shock:
Rotate in 5 degree increments--that will probably do 90% of what I need, and faster than typing. 8-)
beefy
Re: nest question
Post by beefy »
I bet it gets better, my guess is you'll be able to change that 5 degree setting somewhere in Application Options.
Anyway, glad to see a couple of extra yippees, brings back happy memories :lol:
Keith.
LinuxCNC
Coreldraw 2019
Return to “SheetCam”
