Possible upgrade from a TM2 to a TM3
- jmsrbrt
I doubt if anyone has both type machines, but I'm looking for insight. The Torchmate 2 comes with one X axis motor, whereas the Torchmate 3 comes with two X axis motors. My question is, would there be any noticeable difference in the accuracy of your cuts, with a drive motor on both sides of your table, as opposed to one drive motor and a driveshaft to the opposite side of the table? Thought??
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
- Gamelord
- 4.5 Star Member
Re: Possible upgrade from a TM2 to a TM3
I think you would only see an improvement if you are using a large table and your current gantry has some flex or movement in it. The second motor on the other side would help keep movement/flex to a minimum.
If you are using a 4' wide table or smaller, it probably is not going to improve anything.
Torchmate CAD
Torchmate CAD
- jmsrbrt
For any future respondents, I have a 4x8 table, and the gantry is that 80/20 extruded aluminum. The table is constructed from 3 inch square tubing. Everything is pretty much rock solid, so if I'm getting any variances between identical parts, then it must be in loose set screws, stretched belts, or possibly "play" between the spur gears and my gear rack. What, if any, are other possibilities?
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
