Now I got my full version of sheetcam when I import drawings to make posts, I get some red lines, some yellow lines and some blue lines. I need to know what they mean and how to get them all the same I believe red is the default. It seams the posts come out correct when everything is red.
Any Info?
Differnt color lines in Sheetcam what do they mean?
Re: Differnt color lines in Sheetcam what do they mean?
Red is an exterior contour, yellow is an interior (like an inside hole), blue is a rapid movement. (not a cut) White is an open line, as opposed to a "closed" shape. (like a single straight line, or something with lines that aren't joined)
How do you assign what you want. I imported a drawing and one of the cuts is an inside yellow and all the others are red. When I set a cut operation, the green trace lines are one inside and one ouot side. I want them all the same red. So my question is how can you change them in sheetcam.
check this site out. has some good tutorials on sheetcam http://arclightcnc.com/training.html
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
You can select whether the cut is inside or outside offset in the operation--but that will change ALL of them in the drawing--so if all but one are correct in one drawing, you might need to change that one contour to a different layer. That way it can have it's own operation, separate from the rest of the drawing. (Select Edit contours, then right-click over the desired area -> Move to Layer -> New Layer, type a name for your new layer, then assign a cutting operation to that layer)
The first attachment I have this problem with the top of the R. The second drawing I have the problem with the center cut outs 4 are yellow and one is white.
- Attachments
- BR12T 1.5R TUBE MOUNT BAG PLATE.DXF
- (32.36 KiB) Downloaded 117 times
- WARNING THIS IS GARDENA.dxf
- (125.17 KiB) Downloaded 101 times
I figured it out on the warning sign. There was a small little line attached that wasn't needed.
This file should cut good now.
- Attachments
- (124.96 KiB) Downloaded 110 times
