Double tool Path
riddarunner
Double tool Path
Post by riddarunner »
I posting this file everytime i try to load a cut path on it it puts a double cut path on the whole bear holder the other two are fine. I have tried to check for layering and other stuff can not seem to get it right if any body knows the trick please HELP i would like to start using this file have people asking for them.
Napkin holder fixed.dxf
(129.21 KiB) Downloaded 93 times
SignTorch Vector Art
Re: Double tool Path
Post by SignTorch Vector Art »
first, the blue that overlaps the red needs to be moved inside the red so they don't intersect
then every path is open, because there is a lead-in, but the lead-in is on the wrong side, those need to be removed
and the outer perimeter shape is all fragmented and not closed, that part has to be redrawn entirely
