Harbor Freight tubing roller
All topics related to bending, forming, notching, drilling, saw cutting, etc.
762frmafr
Post by 762frmafr »
Who has one? I just got one together from Harbor Freight and everything from Swag Offroad. If you do have one, what are you doing to keep everything rolling straight and true? I tried mine out today with a piece of 1" round, and made a cool looking squiggly. Feel free to share your thoughts and ideas.
VSAW
Re: Harbor Freight tubing roller
Post by VSAW »
We used to have one where I worked. Used it for all kinds of things. We mounted it to a table. You have to kind of hold the item to keep it straight.
kbenz
Post by kbenz »
One person on the roller and one keepin it straight
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
762frmafr
Post by 762frmafr »
kbenz wrote:One person on the roller and one keepin it straight
I am only a one man shop.
HammerDownJustin
Post by HammerDownJustin »
Maybe you should make a jig to hold the tube for you then.
Miller 251 Mig
Masons Forge
Post by Masons Forge »
I cut a shim that fits on each side of the top roller. Use 16ga and clean the edges real good and work both shims in at the same time. I'll post the drawing later.
Masons Forge
here is the shim I cut for the roller
Oldsarge
Post by Oldsarge »
You need to make sure when you put your rollers in that they are aligned perfectly with each other, and shim them with washers to make sure they don't move... that's why they make corkscrews. I can roll a ring of 1" tube that comes right together on the ends, as a matter of fact, I usually have to push them past each other to get the diameter I'm looking for.
Also I built my own roller that's the best one you'll find anywhere! LOL!
http://www.youtube.com/watch?v=LuXnc9WzOdw
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
