Any help would be Greatly Appreciated. I'm running candcnc bladerunner2 sheetcam & mach3. When I load the g code into Mach3 everything looks good. (same in sheetcam & my CAD programs) When I run the file it cuts out the file Mirrored & upside down. So basically I'ts cutting out the backside instead of face up. Again Any Help would be Greatly Appreciated..
Thank You..
GDJ966
Mirrored Image
- WyoGreen
Re: Mirrored Image
It seems like I had this problem a long time ago on my CNC router machine. If I remember right (and I may not) the problem was a configuration problem between my table layout and my drawing program. I think it had something to do with where the 0,0 point was on the table versus where it was in the drawing program. Just not real sure anymore. Anyway, compare your drawing program layout versus your machine layout.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Re: Mirrored Image
Your axis motors are running backwards to the correct direction as defined as to how MACH3 expects them to run. You can rewire them for correct direction OR REconfig the axis in setup by changing the active HIGH active LOW setting. that will reverse the direction of the motors.
JUST a thought, (:-) TP
- tnbndr
Re: Mirrored Image
Did this just start happening?
I would search for a setting in the software that says"reverse pattern" or "cut mirrored image" that got checked accidentally.
I actually would like this option sometimes.!!
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
Re: Mirrored Image
Haha well now I feel a little lazy for not reading the post directly below mine! Sorry guys for the duplicate posts. I have been doing a lot of research but have not had the chance to check anything as of yet. Most of the responses seem to be to switch the direction of the x-axis motors and see if that fixes the issue. I've also seen where the CAM software and the CNC software have different ideas as to how the table is set up, where 0,0 is and so on. I will let you know as to what I find and get back with you. I too recently moved my machine and wonder if I did not connect the motors back the way they should be.
Re: Mirrored Image
Thank you all for your responses. This machine is actually new, Bought it about a year ago & just got around to setting it up. So Yes every image I try to cut is mirrored and turned 180 I have tried running some sign torch files and they cut the same. This is my first time using Mach3 & sheetcam. My other machine & router both use Desk CNC No THC. Files load and cut good with both machines. I'm thinking it has to be something in Mach3 that is causing this.. I appreciate ALL your responses and will check out the settings this weekend.
Again thank you ALL.
GDJ966
GDJ966
Re: Mirrored Image
You do have it, assuming you're using Sheetcam. There's check boxes toward the lower right, that say "Mirror X" and "Mirror Y".tnbndr wrote:Did this just start happening?
Re: Mirrored Image
one other thing you need to check when using a table for both plasma and routing. If you use the home function that move the axis to their home position remember routers home up and plasma home down.
- tnbndr
Re: Mirrored Image
Don't see that option. Using Sheet CAM ver6.0.4You do have it, assuming you're using Sheetcam. There's check boxes toward the lower right, that say "Mirror X" and "Mirror Y".
Re: Mirrored Image
version 6.0.14 is whats current just hook up the net and stat sheetcam you will get the newest then.
check image lower right corner
- Attachments
- sheetcam.jpg (13.82 KiB) Viewed 1958 times
