dxf files that won't open
Some of the dxf files I try importing to inkscape open,some don't show up anywhere on the screen. Any tricks for those files that seem invisible?
- WyoGreen
Re: dxf files that won't open
At one time I had this problem with importing a dxf into Corel Draw. Turns out when importing I had the choice of 3D Projection views on that particular dxf, top, side, front, etc. I just happened to notice the choices and picked the top view when opening one of the "invisible" files, and wa-la, there it was!
It's been a while since I used Ink Scape and I can't remember what options you have when importing dxf's, But perhaps something similar is going on.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Some DFX files will not open in Inkscape others will. How the DFX files are created is the reason
So we need to have a few programs that do the same thing for certain files that are oddball?
- WyoGreen
That does seem to be the case. I have several programs, some free, some bought, each of which excels at it's own little nitch. Dxf's that won't open in one, will open in another. I can then re-export the file to dxf, and it will open in the program that couldn't open it originally. It's just an odd-ball format that seems to have many different incarnations.
Such is life.![Wink ;)](./images/smilies/icon_e_wink.gif)
Such is life.
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Download Qcad and resave them as an SVG or a newer version of DXF and they will open up just fine.
I will be giving that a shot tomorrow. Thanks
I dl'ed qcad. That trick works out great on the few files I was having trouble with. Thanks for the tip.
- CNCCAJUN
Also get Draftsight . . . .
Steve![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
