Torch laser cross-hair mount
Topics related to pen markers, remote controls, drawing tablets, & other plasma table related accessories
bauer
1/2 Star Elite Contributing Member
Post by bauer »
For those of you that own (or have a buddy that owns) a 3D printer, I made a mount that holds a set of laser diodes, 9v battery, and micro on/off switch. I have it mounted on my Thermal Dynamics SL100SV machine torch to generate a set of cross-hairs for precise placement of the torch head.
The 2 diodes hole and torch hole have slots and holes to allow a #6 (1.25") machine screws to be placed through to tighten those items down.
The laser diodes are cheap on amazon/ebay.
The various hole diameters used are:
laser-diodes: 0.5"
switch: 0.25"
torch: 1.406"
I have it published on Tinkercad (https://tinkercad.com/things/7t1o1756q7Z) so you can easily modify the mounts to fit your particular needs.
It won't allow me to upload the 3D STL file, so you'll need to download it from Tinkercad above.
Brad B, Haymarket, VA
Torchmate 2x4
Thermal Dynamics Cutmaster A40
Miller Spectrum 875 Auto-Line
Miller Spectrum 375
tnbndr
Re: Torch laser cross-hair mount
Post by tnbndr »
Nice project. Now I need a 3D printer.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
kb3gun
Post by kb3gun »
Thanks for the file. Made one yesterday. Any brand of laser diodes you'd suggest? Lots to choose from on ebay.
Fits the machine torch on my Hypertherm PM45 like a glove.
Thanks again!
-Bill
-Smitty
Torchmate 4X4 Growth Series w/AVHC
Hypertherm PM45 w/ Machine Torch
Miller Syncrowave 210 TIG
cbassjr
Post by cbassjr »
kb3gun wrote:Thanks for the file. Made one yesterday. Any brand of laser diodes you'd suggest? Lots to choose from on ebay.
Thanks again!
-Bill
Looks like you have a 3d printer. How much to make me one???
kb3gun
Post by kb3gun »
Sorry. Made it at work with some material that was about to expire. I can't make any more.
If you go to the site of the file, there is an option to have it made for you.
-Smitty
Craig
Post by Craig »
Nice setup Brad made one for myself.
http://www.plasmaspider.com/viewtopic.p ... lit=+laser
The only thing I would add is something to cover your wires. I use heat shrink tubing but aluminum tape or other materials will also work.
On my first laser setup, a spark burned through one of the wires in about 3 months.
Craig Johnson
Craig Johnson
gamble
Post by gamble »
Very cool. I bought a laser from someone is it normal for the lines to move depending on torch height? I'd like something that stays the same. I spent more time adjusting it than it was worth. :lol:
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
beefy
Post by beefy »
gamble wrote:Very cool. I bought a laser from someone is it normal for the lines to move depending on torch height? I'd like something that stays the same. I spent more time adjusting it than it was worth. :lol:
Assuming the laser beam is not curved :lol: that indicates the beam is not parallel with the z-axis travel.
Keith
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
bauer
Post by bauer »
Thanks again!
-Bill
I guess I could make you one if you haven't found somebody. How's $30 delivered? I have probably 10 filament colors but I don't remember off-hand which ones. Typical ones.
Brad
Torchmate 2x4
Miller Spectrum 375
mdwalker
Post by mdwalker »
Brad, I would be interested also if you are interested in selling some. Does $30 include the lasers?
Danny
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
gamble
Post by gamble »
I'm really wanting to weld the one i had made to my torch holder, but if it's just a hair off it's going to be a waste of time. anyone have any good ideas on how to tackle this one?
cbassjr
Post by cbassjr »
Thanks again!
-Bill
Brad
Works for me pm me your address info and I'll cut and send you a check if that is okay.
bauer
Post by bauer »
mdwalker wrote:Brad, I would be interested also if you are interested in selling some. Does $30 include the lasers?
Danny
I was thinking just the mount. You'd be responsible for the battery, switch, wiring, and lasers. You can get a laser line diode on Ebay for under $4 (http://www.ebay.com/itm/650nm-5mW-Red-L ... 0982108805).
I have Light Blue, Yellow, Purple, Orange, Black, Red, White, Dark Blue, Green, and Pink filaments (plastic) on-hand.
Brad
Torchmate 2x4
Miller Spectrum 375
kb3gun
Post by kb3gun »
Brad[/quote]
Are you guys just connecting these 4.5v diodes in series to power them with a 9v battery?
-Smitty
WyoGreen
Post by WyoGreen »
I purchased a pack of 5 cheap laser line diodes off Ebay. 2 were bad right from the start. The other 3 had either the + or the - wire shorted to the laser case. When you insert a + short and a - short into a metal holder, things don't work so good. They'd probably be fine in a plastic holder. So cheap laser diodes are just that, cheap Chinese junk. I've since done a little research, the voltage needed to run a diode depends on the color. A red diode needs 3.3 volts. A white diode needs 5 volts. (If I remember right). So if you use a single red diode on say a 5 volt supply, you need a dropping resister in series with it to drop the voltage to 3.3 volts. You can put two diodes in series, so in the case of 2 red diodes, you'd need 6.6 volts across them. Don't use a wall plug power supply on the diodes, they are usually way off voltage and are rarely regulated. A power supply out of an old computer is regulated, and will give you 3.3, 5, and 12 volts.
I've got 2 better laser line diodes on the way from an American company (probably still made in China, although they say American made on their web site.) Plenty of other projects to keep me busy until they arrive, then I'll continue on with this project.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
_Ogre
Post by _Ogre »
i use the 5 volt leads on the pc power supply and it works well
the thing nice about using the pc power supply is that you can trigger it with the aux outputs on bladerunner
while i've never had a bad laser out of the box, i have gone thru 5 of them in 18 months
i bought 2 for the initial test and then bought a lot of 10 for $29 with free shipping
at $2.90 each i'm not going to complain about them not being robust enough :lol: :mrgreen:
bauer
Post by bauer »
kb3gun wrote:Are you guys just connecting these 4.5v diodes in series to power them with a 9v battery?
Yes, that's all I'm doing. Works fine with no trouble
Brad
Torchmate 2x4
Miller Spectrum 375
Return to “Pen Markers, Remote Controls, Drawing Tablets, etc.”
