mach3 control
Hayman
mach3 control
Post by Hayman »
some hoe mach3 is sending a pulse signal to plasma cutter causing it to come on then go off is there a way to fix this
fergy
Re: mach3 control
Post by fergy »
Turn it off
Seriously man no one can help you if you don't tell what you are running
The guys and gals here are good but you not helpin yourself much
Oh and welcome to plasma spider ;)
Hayman
Re: mach3 control
Post by Hayman »
I'm running Windows 7 and mach3 snap on 60i plasma machine when I unplug plasma cutter from computer it works great when it's plugged in computer it sends pulse to plasma cutter I get message pwm bumped to minimum settings
chasxjs
Re: mach3 control
Post by chasxjs »
PWM = Pulse Width Modulation. This is generally used to control the spindle speed on a mill.
Are you using the mach3 program set-up for a Plasma table or a Mill?
Which post processor are you using?
Charles
____________________
DIY 5x5 Folding Plasma Table
Hypertherm PM45
Lagun 4 axis CNC Mill
Shopsmith Lathe
Multiple saws, welders, etc.
Return to “Mach3 & Mach4 CNC”
