Anyone here use one of these?
http://www.ebay.com/itm/HB-5800-Hand-He ... 3cf52a8a14
How well do they work ? And would it be good to remove some dross on a larger piece?
Anyone use a burnisher?
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
Re: Anyone use a burnisher?
here is a demo video but does not show much working action. I would not like to pay and find out it will not remove dross.
It also looks like the replacement brushes are expensive too!
https://www.youtube.com/watch?v=gEjxSmcHgzE
Clown has the camera upside down.
- Gamelord
- 4.5 Star Member
Because of the expense on the brushes I wouldn't waste my money on removing dross with it. It is designed to polish stainless and is not a grinder. Muriatic acid for a couple hours and a quick brush-over with a flap disk and dross is history, takes seconds to remove.
Torchmate CAD
Torchmate CAD
- tnbndr
One is on my wish list but Metabo brand.
They are not meant for dross removal but to put different finishes on metal surfaces or polish metal to different glosses.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
- kb3gun
I have a Metabo. Like others have said, it's not for dross. It would work but the discs would wear quickly. I use it for polishing stainless and for when I want/need a linear finish.
-Smitty
Torchmate 4X4 Growth Series w/AVHC
Hypertherm PM45 w/ Machine Torch
Miller Syncrowave 210 TIG
I have one with an inflatable wheel and use it as a drum sander, doesn't remove dross, but gives you a cool brushed stainless look.
Link? I'd like to see this
Good morning gentelmen
I have two of these however they are the German Poly PTX machines (I think they are the originators). I have all the accesories and they are many, however mostly use it for stainless. Metabo now make an equivalent with the same accessories. For doing flat surfaces it is great, stainless finishing using 3M 'Trizac' is the way to go. If you need any more info, let me know.
- tnbndr
Gamble:Link? I'd like to see this
This is just one brand available.
https://www.walter.com/en_US/products/a ... atic-drums
Warning, not cheap.
