Hi all
I have a Koike table with Promotion Controls . I have had this problem off and on when first turning the computer on a grey screen appears and no boot up of Windows XP. When this happened previously I did a forced shutdown turned on again and windows booted up. The screen usually blinks twice before Windows boots.
Not this time no boot up. Anyone else have this happen any insight would be appreciated. Have contacted Victor Technologies, they bought out Promotion but being the weekend ......
Thanks in advance.
Solomanb
ProMotion Windows XP Grey Screen
Re: ProMotion Windows XP Grey Screen
check the battery in the PC
Thanks for the reply
Changed the battery screen blinked once then when gray and there is a beeping from the small speaker they have in the cabinent. This beeping was not consistent with each restart. They still haven't returned my call maybe soon.
Thanks Solomanb
Thanks Solomanb
If you google the mother board name with beep error is should tell you what the number of beeps mean.
Most mother boards have their name screen printed somewhere on them. Look for a name and model number.
Mine is ASUS B85M-G jsut for reference as to what it looks like
try this site http://www.computerhope.com/beep.htm
here is another https://kb.iu.edu/d/afzy
something is broke if it beeps
With the newer computer mother boards if you loose the disc or mother board you will need to start over and load all the software.
A back-up disc will not help unless you replace the mother board with exactly the same one. What you will see is the computer starts the boot and gets to a point where windows displays its splash screen and then it reboots. This will repeat over and over again with out a complete boot.
Evening CourtJester
I reseated the ram and booted up with the keyboard pressing F1 . They emailed and I sent pictures to them tonight . Good bunch of guys I found out ESAB and Victor Technologies are merging from them. One guy in Texas and the other in Ohio .
Thanks for your help
Solomanb
Solomanb
