Odd pause in motion...
davek0974
Post by davek0974 »
Been cutting a bit today and some of the parts had many 12mm holes in them, I always try and keep the lead-in to the centre so had a 6mm perpendicular one programmed.
When the cut starts, the IHS is done ok then the torch drops to cut height and runs the lead-in but when it reaches the perimeter there is a clear and definite pause in motion, not seconds but very noticeable.
G-code shows a G03 in use here.
On a shape cut, i still use a 5-6mm perpendicular lead-in but the is no delay at all - it just runs from lead-in to cut as expected.
G-coed shows G01 in use.
Is there a reason for this or something i can check as its not doing my divots any good at all :(
tnbndr
Re: Odd pause in motion...
Post by tnbndr »
Have you tried using an "arc" lead in, instead of perpendicular? May give you a smoother transition.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
davek0974
Post by davek0974 »
Not specifically, only noticed this yesterday, only does it with circles not lines and shapes??
SeanP
Post by SeanP »
Are you using any sheetcam rules?
I can get that pause but not on inside circles it's usually on a outside cut if I use perpendicular lead in.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
davek0974
Post by davek0974 »
Hi
yes there would have been a 60% reduction in speed in force but thats all really.
I use perpendicular on all jobs but it only does the delay on holes??
SeanP
Post by SeanP »
davek0974 wrote:Hi
That's odd,
Does it disappear if you turn off thc?
This is what I use on holes less than 35mm dia
Powermax XP45
Table build gallery
davek0974
Post by davek0974 »
Thats pretty much identical to my setting, thanks
I will have a go with THC off next time i'm running.
Brand X
Post by Brand X »
tnbndr wrote:Have you tried using an "arc" lead in, instead of perpendicular? May give you a smoother transition.
That causes a pause in mine.. I kind of thought it might be a SheetCam issue? I just stopped using it, and just use the other two lead-in styles..(for now anyway)
Mine is the 3100 series THC..
davek0974
Post by davek0974 »
Cant see how it can be sheetcam, my money is on Mach3 or THC possibly. The G-code created by sheet cam looks ok.
KIDTech
Post by KIDTech »
I had a similar issue when I uploaded the tool files from CandCNC, turned out to be the THC ON/OFF command in the g-code was pausing my machine.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
davek0974
Post by davek0974 »
Yes
I have Les over at Sheetcam looking at that now, I have a double S10 code entry where it should not be, that is the suspect at present.
I have narrowed it down to where sheetcam auto detects outside or inside cuts -
Job has outside cut only = code ok
Job has inside cut only = job ok
Job has outer and inner cuts, sheetcam set for outside and auto detects the inside = duplicate entries.
Dave
Brand X
Post by Brand X »
davek0974 wrote:Cant see how it can be sheetcam, my money is on Mach3 or THC possibly. The G-code created by sheet cam looks ok.
I have had SheetCam for about 12 years, and always check with Les on funny things happening like that.. You tend to get it resolved one way or another..
Return to “Mach3 & Mach4 CNC”
