CandCNC Control Box
KIDTech
CandCNC Control Box
Post by KIDTech »
When I am done for the day should I just shut the motors down on the control box using the front faceplate or should I flip the switch on the bottom of the box to kill the power? Any help is appreciated.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
motoguy
Re: CandCNC Control Box
Post by motoguy »
Press the red button on the faceplate. You'll see the yellow "dump" light come on for a few moments. When the yellow light goes out, and it's only the red light, then flip the switch.
tcaudle
Post by tcaudle »
Its basically in standby with the motor power off, If your area is prone to electrical storms I would power down completely. You need to power up the PC first then the main box. Surge protectors just stop arcing. They won't save electronics from even a moderate line surge.
WSS
Post by WSS »
I have an older system (PlazPak 4+) that we completely disconnect when not cutting. Once computers are shut down, we de-energize a two pole relay and ALL power breaks from all elements of the table. This includes a oxy/fuel console, I/O control box, CandCnc controller, computer, air solenoids, air cooler for compressor and fans.
We have been running this table for probably five years in a work environment (four to five hours a day) with ZERO issues.
Return to “CandCNC Forum”
