4x4 DHC2 downdraft cone DXF??
Binderman
Post by Binderman »
Our Ag Dept wants to make do a downdraft setup on their 4x4 table to keep the dust and fumes down so that the rest of the shop can be used while the PlasmaCam is running. There is a permanent rust ring on the toilet in that building......
I know of the skirt drawings that come with the table but was wondering if anyone has the DXF for the cone style setup.
Any help would be appreciated!!
PlasmaMac
Re: 4x4 DHC2 downdraft cone DXF??
Post by PlasmaMac »
This plasmcam owner has a few helpful tips on his youtube video.
https://youtu.be/N_Wqsb_vNkc
Loots of people have refered to this pic listed below as thir inspiration. By the looks of it, you cloud make something like this in no time especially with if have something like a plasmacam to cut and lay out the parts with.
The side skirts planel design with the software for you machine, that plasmcam provides already to cut out a made the down draft set up for our systems set and going almost immediately.
Good Luck Brother
_ JAG
Joe Jones
Post by Joe Jones »
That is nice. I am working on a downdraft system that contains a conveyor belt to pass small parts which drop through the grate to a trough at the end of the table, while allowing the dust and slag to fall harmlessly to the collector at the bottom. The air flow will be similar, except that there won't be any tube to step over as you walk around the table, because he air will exhaust beneath the floor that the table sits on.
