Hello
I cut a lot of 16 gauge hot rolled steel, I have a Hypertherm 1000 using fine cut tips 40amps, 152imp
I have the machine set up and it cuts very clean with minimal to no dross build
up. My problem is when I go to cut 16 gauge cold rolled steel using the exact same set up it cuts like crap
lots of dross on the back side, hard to grind off, can any body advise me on why it does this and suggest any change's
on my set up to cut better. Thank You
Cold rolled steel cut problem
- BTA Plasma
Re: Cold rolled steel cut problem
Your speed is TOO SLOW. You should bump it up at least 50ipm
If Matt is using this profile he is one of the OGs of Plasma. If not then a technician. We make the worlds fastest and largest CNC plasma tables up to 10x40. www.StarLabCNC.com
Check out our Facebook page where we update frequently. https://m.facebook.com/StarLabcnc/
I cut 14ga cold rolled with a Hypertherm 65, finecut, 45 amps, 200 ipm. Minimal dross. What I do get chips easily.
I would probably lower amps by 5 and speed up to 225 with 16 ga.
I cut 14g (hr, CR, p&o) with PM85 at 200ipm, 88 amps, 45a fine cut. Book is 225, 82A. I was having issues not cutting all the way through in spots. Slowing it down seemed to help.
I cut 16g hr today at book specs. 250ipm, 78v, 45a.
Dross comes off a lot easier on cold roller and P&O steeleteled wrote:Hello
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
Hello thank you for your suggestions I will try speeding it up Thx
my book says Arc Current 40 Arc Voltage 79 150 ipm .08 distance
