Thanks for any input.
Thanks! I haven't gotten that far yet.Larry83301 wrote:By nesting them just right and changing the tip of one leaf you can get 8 of these on a 4 X 8 sheet with room to spare. Hope this helps you with pricing the parts.![]()
The box is 47 1/2" wide and 46" tall. I changed the leaf tip on the one fifth from the right.![]()
Probably as part of the design unless it works out better to weld round bar on back. I'm guessing I'll be better off cutting it as one piece.mdwalker wrote:Will the spikes be welded on or will they be cut as part of the design?
Correct. I was told to tweak them if need be for whatever makes sense. And we plan to cut other items into the waste. I haven't had time to lay them out yet but wanted to get the ball rolling on some opinions.mdwalker wrote:That will make a big difference in how they will nest and how many you can cut from a sheet.
Unfortunately, no. I use FlashCut and I am not able to export DXF's with the standard version. I bought a new computer today so I don't have Inkscape or anything else loaded yet. I'll get them installed tomorrow.mdwalker wrote:Are you able to post the dxf file of your picture? I may have time to play around with it some
Probably just deburring them. They will be getting powder coated eventually.torched wrote:How are you finishing them?
