Open paths are being closed
Opens are being closed what can be causing this?
D.I.Y 4x4 CNC Plasma Table with water tray
60 Gal. A/C + D.I.Y Aftercooler + Water/Oil seperator + Desicant air dryer
45XP (CPC with hand torch)
MiniTHC
UCCNC + Sheetcam + Inkscape / AutoCAD
MiniTHC
Re: Open paths are being closed
Ok found the problem: overcut should be set to 0" for open paths
MiniTHC
MiniTHC
Carefully continue to read all the options. Off set open paths and lead in on open paths is checked
If I am cutting lines (open paths) I use "no offset" and no lead ins.
