Hypertherm powermax 45 30 amp consumables?
I know i purchased them before but i am forgetting the part number..Hypertherm makes 30 amp consumables for the powermax 45 that fit the 45 amp swirl ring and retainer and use the 45 amp shield as well..Does anyone know the part number ..They came in a kit with two nozzles and two electrodes?
- tnbndr
Re: Hypertherm powermax 45 30 amp consumables?
This is from the PM 45 Manual.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Those are the powermax 30 consumables which require you to run the 30 amp retainer,swirl ring and shield for a 30 amp.. the consumable kit I am talking about comes with two tips and two electrodes that are 30amp for the 45 amp retainer ,swirl ring and shield
I'm currently in the same position. Looking for 30 amp electrodes that will work with the powermax 45. Any luck?
