Shop Miracle
larrycameron44
Shop Miracle
Post by larrycameron44 »
So today while doing some cutting I had forgotten to turn on the compressor in the shop. I have 3 air reservoir which enable me to cut for 7-10 mins with my powermax 45. Torchmate 2x4
Well as I was wondering what was missing, which was the noise from “the compressor humming away “, I looked at the powermax and noticed the air light was in the orange not green.
I stopped immediately thinking the cuts must be crappy with so low air pressure......... but to my surprise, the least dross on 2mm CR mild steel in 6 years.
So lesson for me was reduce air pressure a bit and better cutting. It was initially set at the upper green light.
Cheers
Larry Cameron
RusticMetalArt
beefy
Re: Shop Miracle
Post by beefy »
Thanks very much for sharing that Larry.
I'm guessing you were using Finecuts on 2mm thickness.
I would never have thought to try turning the air pressure down that far to get a better cut.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
RAD
Re: Shop Miracle
Post by RAD »
Happened to me before along with forgetting to attach the work clamp! So now I have this checklist in my head before I start a job
D.I.Y 4x4 CNC Plasma Table with water tray
60 Gal. A/C + D.I.Y Aftercooler + Water/Oil seperator + Desicant air dryer
45XP (CPC with hand torch)
MiniTHC
UCCNC + Sheetcam + Inkscape / AutoCAD
larrycameron44
Re: Shop Miracle
beefy wrote:Thanks very much for sharing that Larry.
Keith.
Yes was using the 30 amp consumables. :)
Larry Cameron
RusticMetalArt
