Table not cutting square
Dooggins1
Post by Dooggins1 »
I am having an issue with my table not cutting a square, square. I have turned it off and moved it to the front until it's stops to try and square it back up but hasn't helped at all. Any suggestions??
Re: Table not cutting square
It would help if you state what table you have, there are many users here that have different manufactures tables. Maybe someone who has that brand can be a better help for you. Is this a new table, DIY, dual motors ect.
Dooggins1
Post by Dooggins1 »
acourtjester wrote:It would help if you state what table you have, there are many users here that have different manufactures tables. Maybe someone who has that brand can be a better help for you. Is this a new table, DIY, dual motors ect.
The brand is gorilla machines. He is based out of Asheville nc. I believe only one motor on the side.
Well they have "24-hour support following sell". Toll-Free: 800-340-5526 Local Tel: 828-593-0405
Feel Free to give us a call anytime. We love to talk shop and are happy to answer any questions you might have.
If that is a bolt together table it may have gotten out of square and may need to be adjusted to make it square again. :(
Old Iron
Post by Old Iron »
Measure diagonally across the the table both directions and if the measurements aren't the same then, make them the same.
