70 Ford Mustang DXF File
Any one willing to share a 70 Mustang.
Re: 70 Mustang
Try this one
Re: 70 Mustang
Awesome thanks so much appreciated
Terry
Terry
Re: 70 Mustang
Nice file. Thanks for sharing
Re: 70 Mustang
That is slick. Thanks.
Re: 70 Mustang
Very Nice, Thank you..
4' x 4' DIY Table
CandCNC Bladerunner
Miller Vintage 250 Mig
Miller Syncro 180 Tig
Bridgeport 2J Mill - Fagor Dro
Southbend 14" x 40" EVS Lathe - Fagor Dro
Brook 18" Metal Shaper
Harig 612 Surface Grinder
CandCNC Bladerunner
Re: 70 Mustang
This file needs work, bridging some of the drops.
- Joe Jones
Re: 70 Mustang
If you cut that with a plasma cutter, a lot of the detail will drop out. It is a nice file, but it needs some TLC before it is cut ready.
Re: 70 Ford Mustang DXF File
I cut it last week, and thought i sorted it, but the windows came out
Post your edited cut file and I will have a look.beeson1987 wrote: Mon Oct 03, 2022 2:13 am I cut it last week, and thought i sorted it, but the windows came out![]()
- Joe Jones
"DRIVE the design." Using your eyes, imagine you are looking at a map of the land mass in an ocean. The PURPLE is the land, the BLACK is the water. If you can drive your car from any point to any other point on the LAND without crossing water, then the design is cut ready. If you need to "build a bridge" to get to any point on the design, then you have an "island" which is a part that will fall out of the design, because it is not connected to the rest of the land mass. In this design above, the windshield, the wheel detail and the headlight crescent accent are all islands.beeson1987 wrote: Mon Oct 03, 2022 2:13 am I cut it last week, and thought i sorted it, but the windows came out![]()
Great explanation of how to look at it Joe!!Joe Jones wrote: Mon Oct 03, 2022 8:19 am"DRIVE the design." Using your eyes, imagine you are looking at a map of the land mass in an ocean. The PURPLE is the land, the BLACK is the water. If you can drive your car from any point to any other point on the LAND without crossing water, then the design is cut ready. If you need to "build a bridge" to get to any point on the design, then you have an "island" which is a part that will fall out of the design, because it is not connected to the rest of the land mass. In this design above, the windshield, the wheel detail and the headlight crescent accent are all islands.beeson1987 wrote: Mon Oct 03, 2022 2:13 am I cut it last week, and thought i sorted it, but the windows came out![]()
JJ-70 MUSTANG2.dxf
RAYZORcut
