BrianMick wrote:Great Idea shawn, Ive got a couple of lanterns at home, I might just give it a try...
Brian,
They don't take too much time to make.
My wall boxes did not have wall switches to turn them off and on, so I drilled a small hole in the bottom of each lantern so I could install a push switch.
On my lanterns I had to take out the part where the original wick comes through and put it in a vise to cut off the nipple and make it flat (hacksaw).
You will put the wick base back on the lantern, just cut enough off to mount the socket.
Once I did that, I drew a circle and cut it from 14 Ga to fit inside the lantern (where the glass sets on) tack weld it in place.
In the center of that circle you cut, cut another hole to fit the light socket in and bolt it in place. So... a circle with a smaller circle in the middle.
I ran all the wiring through the oil tank and ran it up the hollow tube that goes up through the lantern.
Drill a small hole in the back of the lantern (very top) run the wire out this hole.
Make sure you install a grommet in that hole where the wire comes out of the lantern and goes into the wall.
That hole will have some very sharp edges and could cut the electrical cord over time.
Wire it up and now you have a lantern light.
Sounds like a lot of work but it only took me about 30 minutes per lantern to make everything fit.
I bought small sockets and small light bulbs thinking at the time it may be to dim but it was perfect.
They put out a good amount of light.
I was looking to get enough out of them to read by at night.
If I turn both on at the same time, it is enough to light up the entire room but doesn't feel like you are staring at a light house
Also..... If you assemble them like this, the globe still removes like it did before the lantern was modified.
This makes it very.... very.... easy to replace a burned out light bulb.
Just pull up the spring loaded top cap, tilt out the glass and change the bulb (just like replacing the original wick).
Ended up more than happy with the results.
Hope this helps, just may save you a little time if you make a set.
