Sheetcam export cut paths at different levels
jaker2
Post by jaker2 »
Hi there, pretty new user here and looking for a bit of advice....
working with sheetcam (only one layer) I am exporting to gcode mach 3 and seeing cut paths on different levels (see attached). I have tried to look for what settings cause this to no avail so I thought i'd come to the experts.
Any thoughts for a newb? Thanks, Brad
8-30-2018 11-26-46 AM.jpg (37.22 KiB) Viewed 559 times
tcaudle
Re: Sheetcam export cut paths at different levels
Post by tcaudle »
Do not use a 3 D view for plasma cutting. Waht you are seeing is the code trying to get the Z potion from ouch offs that are not happeneing at the time the code is loaded. Turn it up so you have the top view. Its not a SheetCAM problem its the toolpath not being able to figure out were Z is at any given time from the code.
jaker2
Post by jaker2 »
Ah ok thx.....seems i'm loading gcode prior to getting everything set.
Appreciate the response!
B
Return to “SheetCam”
