Here are some cuts that my 5x10 diy plasma table with floating head, Running sheetcam, mach3, nema 34 "x" nema 24 "y" and "z" THC not working yet. Using a everlast 80s pt80 machine torch on 1/4 cr plate. Cut height .060 pierce .120 delay .5 60amps 1.2mm nozzle
I made a line speed test at first with 13 lines 6" long starting at 20ipm running 5ipm increments on each line. Then after that I made a 5 line test starting at 30ipm working my way up 5 ipm at a time till I got to 50ipm the outside square is cut a 46ipm.
I have rotated the file in sheetcam to check lines on both "x" and "y" axis.
It seems like my y axis is losing steps or something is off? I have checked backlash, motor tuning and calibrated all axis down to .0002 accuracy. Also when the cut goes from "X" then 90 degrees to the "Y" axis it picks up a dip in the cut? But from "Y" 90* to "X" it's perfect! ?!
This is my first major post so I hope I have provided enough information as detailed as possible.
Any input or information will be greatly appreciated.
Thank you.
Opinions on first cuts after calibrating and squaring
Diy 5x10 plasma table
Everlast 80s plasma Everlast 250 tig
Lincoln 350mp mig
Bridgeport series 1 and 2
Webb 3vh vertical mill
Brown and sharpe horizontal mill
South bend 14.5 x60 metal lathe
Old 65 ton piranha iron worker
Lincoln 350mp mig
Re: Opinions on first cuts after calibrating and squaring
none of the pierces look like holes.pierce heights are off definitely. I've built a lot of 3d printers i would guess your steps per mm is off for what ever motors you using. tape a needle to the torching set down a ruler and move x 10mm and see where its at then do y same should find problem.
I did find a few problems I am currently correcting.
1. Loose pinnion gear set screws on y axis
2 . Timing belt fitment on pulley
3. peirce delay is now set to .8 instead of .5
Lincoln 350mp mig
Lincoln 350mp mig
Also found in sheet cam I had "loop sharp corners" on.
Lincoln 350mp mig
Lincoln 350mp mig
Quick update. After filing deeper set screw flat spots on my shafts and finding the right timing belt. All is well.
Turned loop sharp corners off in sheetcam and changed pierce times and the lead in and out position.
Here's some new pictures of my 5 ipm incrament line speed testing on the y axis.
Opinions and advice are always appreciated.
Lincoln 350mp mig
Lincoln 350mp mig
I'm thinking 40 to 50 ipm looks great at 60amps?
Here's a backside photo and all corners are square.
Lincoln 350mp mig
Lincoln 350mp mig
