How do I change to a new computer
Torchmates software related questions and tips can be posted here
vogelsangd
Post by vogelsangd »
I have the table hooked up to a computer which I use for cutting parts. I need to change to a new computer. How do I transfer the cutting software with all the settings in to a new laptop? Anny help is much appreciated.
Software
Version: 4.0.61
Configuration Files
Setup: C:\Torchmate Data\Torchmate 4\Setup\Torchmate2x4Plasma.STP
Tooling: C:\Torchmate Data\Torchmate 4\Tooling\Torchmate.tlg
User: C:\Torchmate Data\Torchmate 4\User\Torchmate.usr
Signal Generator
Model: 501A
Torchmate must connect to the Signal Generator at least
once to display more information
USB Connection
Data Rate: Hi-Speed
Remote Control
Status: Disabled
Plasmatech 4 x 4 with Hypertherm 45XP
gamble
Re: How do I change to a new computer
Post by gamble »
You can download version 4 or 4.5 off the Torchmate website.
Back up the other files to usb or dropbox and load them once the new software is installed.
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
brandoncp
Post by brandoncp »
which files do you replace on the new computer? The lady I talked to twice at Torchmate so far today has no clue what I am even talking about.
I am using the older torchmate 3 set up. I transfered the 3 files from my old computer to a hard drive. One is the Torchmate driver folder which I already used to update my driver. To get my set ups tranfered over though I don't remember which folder to replace (I did it several years ago with the help of a Torchmate customer service person). I have the folders Torchmate Data and the Torchmate 3 folder from Program Files (x86). Do I replace them all or just some or........? Any help would be appreciated
gamble
Post by gamble »
This is your setup file. Save that file to replace the default file when you install the software in your new computer. You should probably name it something else so you don't get it confused
Download the software from here
https://torchmate.com/driver-software-downloads
In each software, the last item in the menu should be help or about. That will tell you the version you are currently using.
Itsmejoe231
Post by Itsmejoe231 »
I am kind of doing the same thing here. I sent one of my old pc’s to be upgraded and it had the 2x4 setup files on it and worked just fine. In the mean time I brought out my old laptop but it only has the 2x2 setup file on it. I upgraded from 2x2 to 2x4 years ago but never put the 2x4 set up file on my old lap top. Is there a place I can download the 2x4 set up file?
BAR M
Post by BAR M »
When my computer had to be replaced, I went to a small shop that built gaming systems and asked to clone my dead system and he did just that. Everything came right up when I set it up in my shop.
